Après moult recherches , j’ai enfin mis la main sur la procédure pour remettre à zéro le voyant airbag du tableau de bord , qui clignotait après débranchement de la batterie .
Elle existe aussi peut-etre par ici, mais ne l’ayant pas trouvée , je vous en fais profiter.
A noter que cela marche pour les D40 , ça vient de marcher pour le mien . Une autre procedure existe pour le D22.
**RESET METHOD:
If you have the airbag light blinking here is how to reset it:
- Turn the key from off to on.
\ - Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
\ - Count to 5 (1 Mississippi, 2 Mississippi . . . .)
\ - Repeat steps 1-3 two more times until you have done the cycle three times.
\ - Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
\ - Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.**
