bonjour,quelqu un connait il la procedure pour entrer le code dans une nouvelle cle
garage
tu as tout ici si tu maitrises l’anglais et tu t’inscris sur le forum, y a tout un thread là-dessus:
Here’s the procedure.
ID Code Entry Procedure
Note:
A maximum of four remote controllers can be entered.
Any attempt to enter a remote controller will erase all ID codes previously entered.
Therefore, be sure to receive all remote controllers from the vehicle owner when any ID code entry is performed.
Enter the identity (ID) code manually when:
- Remote controller or control unit is replaced.
- An additional remote controller is activated.
To enter the ID code, follow the procedures below:
PROCEDURE
- Get inside vehicle, close all doors and lock driver side door using doorknob.
- Insert and remove the key from the ignition more than seven times within 10 seconds.
- Turn ignition key switch to ‘‘ACC’’ position. (The hazard warning lamps will then flash twice.)
- Turn ignition key switch to ‘‘OFF’’ and remove the key from the ignition.
- Push any button on the new remote controller once. (The hazard warning lamps will then flash twice.)
At this time, the new ID code is entered and all previous ID memory is completely erased.
Q. Do you want to enter any additional remote controller ID codes?
No, Open driver side door, procedure completed, test system.
Yes, continue the procedure below:
ADDITIONAL ID CODE ENTRY:
- Release the door lock, then lock again using driver side doorknob lock switch.
- Push any button on the additional remote controller once. (The hazard warning lamps will then flash twice).
A maximum four ID codes may be entered. (After 4th ID code is entered, the registration mode is ended.)
- When programming completed, Open driver side door, procedure completed, test system.
ENDS.
N.B.
After entering the identity (ID) code, check the operation of multi-remote control system.
NOTE:
- If you need to activate more than two additional new remote controllers, repeat the procedure ‘‘Additional ID code entry’’ for each new remote controller.
- Any ID codes cannot be entered after termination of the ‘‘setting mode’’.
erreur de postage
il en existe une autre suivant l’age du véhicule…
Activation of the registration mode:
The vehicle must have been unlocked by either the multi-remote controller or a transponder OK signal (TPOK) from the vehicle’s immobilizer.
Preparation:
- Make sure all doors unlock.
- Make sure all multi-remote controllers to be registered are available.
- Make sure the batteries of all multi-remote controllers are in a good condition.
- Make sure all transmitting sources are out of the neighbourhood of the vehicle.
- Make sure the battery of the vehicle is in a good condition.
- Switch ignition-switch exactly six times from the “LOCK” to the “ON” position within 10 seconds and return the ignition switch to the “LOCK” position (leaving the key in the ignition switch).
- After 2 seconds the registration mode is activated. The turn signal lamps will flash twice.
OK - Proceed with the registration mode.
No Good – Go back to 1
NOTE:
The confirmation of registration mode is operated when:
- The ignition-switch is turned to the “ON” position.
- 4 multi remote controllers have been learned.
- No multi-remote controller or ignition switch input is received within 120 seconds.
Registration mode
- Press and hold the “UNLOCK” button of the multi-remote controller.
- Press the “LOCK” button 3 times.
- Release the “UNLOCK” button.
If the multi-remote controller code is registered correctly, the turn signal lamp will flash once.
OK - Do you want to register another multi-remote controller? (max. 4)
Yes – Go back to 1 with another remote
After registration of the requested No. of multi-remote controller(s), confirm the ID-code(s) by switching the ignition switch to the “ON” position.
If the multi-remote controller registration is performed correctly, the turn signal lamp will flash twice.
Take the ignition key out of the ignition switch and confirm the functioning of all multi-remote controllers by locking and unlocking the vehicle with each of the multi-remote controllers.
MULTI-REMOTE CONTROL SYSTEM
EL-3139
OK, that’s perfect, I think he will manage to change the code by himself with such a detailled explanation.
…et bienvenue sur “the world famous http://www.pickup-mania.org”
Vous n’avez pas de bon accent.
merci pour cette reponse
mais je n ai pas de cle avec telecommande,c est la simple cle avec puce
j ai ete au garage toyota et il m ont sorti 16 feuilles de procedure pour programmer la cle
j ai pas encore eu le temps de regarder mais je vous tiens au courrant et si ca fonctione je scanne le tout et j essaye de le poster
